This is purely for curiosity sake first off, I know how to calculate gear ratios but one this has been bugging me, I don't care about engine RPMs or how it will throw off my speedo etc., I just want a specific number that I cannot seem to get to
the "effective" ratio depending on tire size, if you search around online you will find several calculators that will tell you how your effective gear ratio will change when you change tire size (old tire / new tire x gear ratio) etc., but what I want to know is what my current effective gear ratio is with the size tires already installed?
Let me explain further, my car has 2.73 gears, TH350 with 2.52 low gear, 27.4 diameter tires, 2.73x2.52=6.8796 how do I calculate the tire size into this, to see how it will effect that 6.8796 final, or more appropriately how do I calculate the tire size with the 2.73 rear, to see what it will effectively make the 2.73 when the rubber meets the road, as it were
its probably going to be so simple that I will hate myself.. but for some reason I simply cannot figure this out and its driving me nuts, furthering my frustration is this, if I follow the equation for "effective gear ratio changes" and just randomly use an "old" tire size such as 26.9 / 27.4 x 2.73 I get a 2.68 rear gear, so that would make the final 6.7536 effectively correct?
but if you change the "old tire" size to something else like 24.5, you will end up with a 2.44, so this "effective" gear ratio is just how the ratios will change depending on 2 different tire sizes? still seems wrong, how do you calculate what your actual ratio is with the tires you have now? what are the 27.4" tires doing to my 2.73 gear?
maybe I am missing something here
