ReQ said:now if you change the tires circumference to say 80" and leave the 4:1 gear and roll the tire one complete revolution, it will move 80" and turn the yoke 4 times, same amount of mechanical reduction (4 turns into 1) but the distance is different, so if you compare the 50" tire to the 80" tire 50/80x4.00=2.50 with the 80" tire you are turning the same amount of rpms to cover a different distance, so that effectively transforms the performance of the 4.00 gears into a 2.50 ratio, BUT only when you compare it to the 50" tire and that has been my hang up, what was the effective transformation of the 4.00 gear with 50" tires? there is no way to get a value for this unless you have another value for comparison, that bugs me
What you're asking, it sounds like to me, is how to compare the 50" tire with the 50" tire, and again, I'm saying, it is a 1:1 ratio. A 50" tire through 4.00 gears is precisely a 50" tire through 4.00 gears. THAT is your answer. It's kind of like throwing a dart at a spot in the wall and asking "how much higher is it?" Higher than WHAT? It just IS. It is exactly where it is, and it is only where it is. If you throw a second dart near the first one, then you can ask the question. But if there's only one dart, the question is not logically valid until you specify what you're comparing it to. Another example, if you throw marble on the ground and ask which direction the imaginary line that passes directly through the center of the marble is pointing. It's impossible to say. There are infinite lines that pass through that point. If you throw down a second marble, there is only one possible line between those two points. It is the same when you name any tire size, and only that tire size, and ask how that tire size affects your final drive ratio. It DOESN'T, unless and until you specify something to compare it to.
