Thanks for the replies everyone however, I don't see that this will fix the problem. The mount listed in my instructions is the same as the energy suspension diagram above. I bought mine years ago from PST. Bushing number 4131 and 4132 are used. If I switch the top and bottom it doesn't fix problem, still have about 1/4" gap between body and top of bushing. I took the #3 bushing out and took a picture of it, as you can see the top and bottom are nearly identical size or thickness. Also the way it's pictured is the way the instructions say to install it, 4131 on top and 4132 on bottom. 4131 is actually slightly thicker at about .93". The bottom is about .90" thick. I will have more time later to investigate.
