el camino v6 frame motor mounts
beanzELCO702
45
How do you take them off ? I got one bolt out. But I can't get the otheres. I was thinking about just cutting the bolts. What di you do to get them oFf
If the lower control arms are removed it's alot easier. You can still get them with the control arms in place from bottom with an a wobble extension and from the holes on the side of the crossmember...it is faster tho cutting them and replacing the bolts..when I did mine I used bolts like this and locking flange nuts...if you put the bolts in from the frame side you can torque down the nuts without having to put a wrench on the bolt head...
