pontiacgp said:there is only one fuse for the wiper motor...if you remove the fuse and turn on the wiper motor then one side should be hot....if not then your problem is from the fuse box to the switch on the column...if is is hot and you install the fuse and both sides are hot but the motor is not working then your problem is somewhere on that side of the box to the motor
Bonnewagon said:Did you get 12 volts at the white wire on the wiper motor with ignition on? If so, you are good. If not, the fuse or wiring is bad. The rest of the system works by grounding, so get 12 volts to the motor first. Then we can troubleshoot the switch.
