Electric choke wire question
565bbchevy
9,614
12,683
Michigan
So I have a couple wires I can use for my electric choke on my Holley carb and both have 12 volts with ignition on.
But when I put either wire on the terminal for the electric choke (which has it's own ground) I only get a reading of 1.8 volts at the terminal end regardless of where I ground it and if I remove the wire from the choke the terminal goes back to 12 volts, is this normal to get the very low voltage reading when hooked up?
MrSony
6,831
6,741
Des Moines, Iowa
Happened to me. I hooked mine up the oil pressure way. No issues.
TURNA
Rocket Powered Basset Hound
Jul 24, 2009
10,941
19,992
Socialist NY
those wires were originally for the emission nonsense sensor junk
I just ran an ignition hot right out of the fusebox
565bbchevy
9,614
12,683
Michigan
One of the wires I tried is for the alternator plug which I don't need with the 1 wire alternator.
TURNA
Jul 24, 2009
10,941
19,992
Socialist NY
1 wire bad!!
:banana:
565bbchevy
9,614
12,683
Michigan
TURNA
Jul 24, 2009
10,941
19,992
Socialist NY
nothing just bored
565bbchevy
9,614
12,683
Michigan
