civi said:
@Skulledmonte84: Hi, I also got the HAYDEN 3652 but don’t know how to start. If you don’t mind, can you please elaborate the pics so that I got the better idea how to install this switch? From your experience, it seems that this will not be a simple job to install this switch.
i was wanting to hide as much as the wiring as i could or make it look like it may have been done by the factory.
The first pic shows i mounted the Fuse Box an Relay to the inner fender,i used electrical tape,Tape the relay an fuse box together.I used a drill an drilled a hole to screw it on with.Ran all the wiring down an across to the headlight harness,Tucked the wires in the wiring "cover" Since i already had my front SS nose loose,i took it off so i could tuck the wiring in around the radiator area .I added longer wire to all but the RED "power wire" i ran it under my battery tray to the + side of battery,
2nd pic just shows the wiring coming from the headlight harness down to the fan wires then the ground wire that i have screwed to the frame were the charcoal canister return line "hold down clamp"would be
3rd/4th pic just shows how the relay an fuse box looks like screwed down,
The green wire got me confused when i read the direction how to hook it up, i got my wire hooked to a toggle switch in my car,That way if the relay stop working for what ever reason,i can just flip the toggle switch an my fans will still work but i will have to remember to turn it on an off every time i drive the car HOPE THIS HELPS
