Unless they had dirty clothes in the radiator.....MrLightning said:most (smart=non ignant) people would never run ONLY antifreeze nor for that matter, add laundry detergent to their cooling system!
khan0165 said:correct... the instructions say that after 50/50 mixture, there is a opposite effect. The temperature range gets shorter and shorter
pontiacgp said:khan0165 said:correct... the instructions say that after 50/50 mixture, there is a opposite effect. The temperature range gets shorter and shorter
true, the point is antifreeze lubricates and may raise the boiling point of water but it does not help with dispensing of the heat of the engine. I would rather use the space that antifreeze takes to use water along with the water wetter to lubricate the system. I use antifreeze in her when I store her for winter, then I flush that out in the spring.
Yep....its call MoonShine!...or White Lightin....or Corn Liquor.....or......lol And, for some reason, we outlawed it!MrLightning said:Do they make a product that makes water.......wetter, keeps the engine from freezing or boiling over AND is good at getting grass stains out? If not, may i introduce you to the next up and coming very successful multi-million dollar entrepreneur. :lol:
Water itself isnt abrasive. When it boils in spots, the temp differences make the metal weak and create cracks that lead to holes. Water wetter will not hurt, but I wouldnt bank on it as the cure all. Distilled water has no minerals which is the leading cause of internal engine coolant corrosion. Most, if not all, antifreeze brands have anti-surfactants mixed in to help the water do a better job of removing the heat, along with lubricators for the pump and anti corrosives for the rest of the system. Water works great, but IMO, it has its limits and is not a better choice than a mix of all the ingredients we have discussed.MrLightning said:as i understand it, watter wetter reduces the surface tension of water, therefore making it less abrasive as it passes through the engine and in turn dropping the boiling point.
