A search didn’t produce any results so I thought I’d put the question out there. After an ls swap my choke light stays on. I know I can remove the bulb, but is there any reason I’d want to rectify it another way?
I thought that was what that was originally used for. At least in the Chevrolet Trucks, that was what they were used for.Use it as a oil pressure warning light.
I guess I’d have to install a pressure switch somewhere to make it work?I thought that was what that was originally used for. At least in the Chevrolet Trucks, that was what they were used for.
It's a dual purpose light. The two terminal oil pressure switch is used to trip with low pressure as we all know & works with electric choke with a power source or the circuit & warns of a issue with the circuit. To be honest I never seen the light tripped by the choke but have had it tripped by low oil pressure.I thought that was what that was originally used for. At least in the Chevrolet Trucks, that was what they were used for.
Thanks, I know that one is still there with the choke pigtail coming off of it.There should be a green wire with a white stripe on the connector to the oil pressure sensor under the distributor. That's the wire that operates the light.
Makes sense.It's a dual purpose light. The two terminal oil pressure switch is used to trip with low pressure as we all know & works with electric choke with a power source or the circuit & warns of a issue with the circuit. To be honest I never seen the light tripped by the choke but have had it tripped by low oil pressure.
