Khan,pontiacgp said:Khan, that's a real nice set up and to keep it that way you might want to consider setting up a dual spring return for your throttle.. 🙂
I am also running a Accel coil, used to have the big Accel cap too... but it turns out a stock cap fits right ontop the big coil anyways. And if you're set on keeping the cap, I've also seen the same airbox cut on the back and refibreglassed.1evilregal said:looks great khan! gives me some ideas, although I'm running a rochester and bigger accel coil, so I'll have to go slightly different.
Thanks Joe, my linkage seems to be a little different. I wonder if it will work there... does the linkage bracket bolt onto the throttle linkage arm? Where does the main braket bolt onto?... intake?JBreu said:Khan,pontiacgp said:Khan, that's a real nice set up and to keep it that way you might want to consider setting up a dual spring return for your throttle.. 🙂
I picked this up on E-Bay from SKip WHite Performmance, summit/Jegs also sell them and it's a direct fit for the Holley carb...
bill said:if I may ... the chain limits the amount of torque twisting of the engine during hard acceleration. Transfers the lost torque to the rear drive train and increases rear wheel torque.... somebody else might be able to explain it better...lolDennyboy said:looks very cool, the tubing looks alot better than hard tubing i have seen used before. I do have one question, what is the chain for?
I get that alot... it's actually hooked onto the fast idle circuit. So on a cold start, I flick the lever over and I got her sitting at 1300rpm till idle stabalizes.chevy2480 said:The engine bay looks great.
But may i make one suggestion it might be time to remove the manual choke cable seeing how you milled off choke tower.
I see says the wise man. Very smart.khan0165 said:I get that alot... it's actually hooked onto the fast idle circuit. So on a cold start, I flick the lever over and I got her sitting at 1300rpm till idle stabalizes.chevy2480 said:The engine bay looks great.
