Hi All,
New member to the forum from Canada (Calgary,Alberta), just wanted to share a couple pics of my 15 year project finally coming to life.
I built the engine sometime in 2005 right after my son was born and it stayed glued to the engine stand while I raised my boy.
Last Sept 2020 I had enough of staring at it and finally got my butt in gear and went to work.
It's pretty much exactly the Hod Rod Olds 455 build of 2003 except for the Professional products Crosswind intake (Edelbrock didn't sell an air gap at the time).
It fit in the 86 cutlass like it was made for it.
Rest of the package is as follows....
Trans....home rebuilt GM 2004r new TCI valve body, B and M 2800 RPM stall converter. Rear axle stock 7.5 10 bolt...LOL ready to blow... new auburn posi carrier, 4.10 richmond gears, hardened axles.
Exhaust - Hooker super comp engine swap headers, cheapo Jegs 2 1/2" gbody exhaust kit (true dual with new G-Force crossmember.
Cooling- 19X31" aluminum rad with Lincoln Mark 8 junkyard electric fan...car runs 175-180F no problems with overheating.
Took it for a quick spin around the block in Feb....WOW...hauls butt...ZERO traction but fun.
Already looking to build a Ford 8.8rear and get some traction into this thing.
Hope the car turns low 13 high 12 quarter mile times when track opens in May.. (we have a high altitude in these parts 3500-3700FT above sea level).
So far TONS of fun!!!
