jmt455 said:
That almost sounds like a bad thermal vacuum switch (TVS) or mis-routed or leaking vacuum lines; like you're porting vacuum to something when it's cold that should not get vacuum supplied until the engine is at operating temp.
Have you verified that all of the vacuum lines are properly connected and that any or all thermal vacuum switches are working properly?
This is very likely part of the problem as the Vacuum timing on the distributor is routed to ported vacuum on the Carburetor. A suggestion made by the shop help (I guess he technically qualifies as a teacher though he is not our head instructor) as we did not have a TVS handy at the time, and since I didn't (and still don't) know which TVS to get. The quick-fix we did there did help with performance, but if it is now causing the car to idle like this, it's time to fix it properly.
To be honest, I don't know what happened to it, all I know is that the switch is broken off on the manifold and it could have been Pep Boys, or some other random shop that broke it off and never said anything. I've owned the car almost 10 years now and as lame as an excuse as it is, I've never been too observant of work done to it, but now that I'm going to school for automotive, I'm quickly becoming much more observant of other people's work (mostly their mistakes).
The same problem exists for my EGR as the vacuum switch there was broken off as well. At this point, I don't even run an EGR, I've been planning on deleting the EGR Valve, but I'll be more than willing to not do that if it is a mistake waiting to happen.
The two previous owners of my car were my Uncle and Grandfather, with my Uncle owning it last. He has very good memory and according to him, when I took over the car it did indeed have all the vacuum equipment. Somebody somewhere decided the car would be better off without it... (I suspect the best place to point a finger at would be the place that installed the rebuilt engine, but ultimately it comes down to being my fault for not noticing sooner)
Clone TIE Pilot said:
When you rebuilt the carb, did you pull out the idle tubes to clean them and the passageway under them? Just soaking a carb won't clean them, it's a very common mistake and a big cause of rebuild failures.
BTW, all US G bodies were computer controlled starting 1981. Many Canadian G bodies never got computer control even though the 80s. So either you have a Canadian or someone swapped carbs or your car is a 1980 model.
Yes, the car is a 1980 year model. When we rebuilt the carburetor we cleaned everything thoroughly. Even after we soaked parts we took the time to scrub them out and make sure they were clean. Also, I believe this car qualifies as an A-Body though it does share a lot in common with G-Body cars.
Bonnewagon said:
It sound like the choke is set wrong. It should be totally closed when cold, crack open a set amount when the motor first starts, then open completely when at operating temp. That set amount is critical, older carbs had a fractional gap of between 1/8" and 1/4". As a rule of thumb, stalling means too much air, stumbling means too little. Once hot, the vacuum should be around 20" and steady at 650 to 750 rpm idle.
I will most definitely crack out my Sears engine analyzer and check RPM and vacuum against one another! As far as the choke goes, I can definitely see what it is doing when to make sure it is doing what you're describing.
