Engine issues
82cutty said:
It could be either a bad plug wire or a bad / cracked plug.... When did it dtart to happen? Was the engine new or old? I would squirt down the plug wires with Spray-9 and run it in the dark to see if anything is jumping. I had a bad wire on my 88 302 Ford engine that was shorting out to the metal heat tape and arching to the header one time.
Steve
the block has maybe 600 miles since last rebuild, but this started when i changed out my head from the worlds prod. to the AFR's and the cam swap, so the top end is brand new from the timing chain up
recheck the timing chain, it might be just far enough off...
other than that, fuel pressure and volume?
Have you put a vacuum gauge on it? Vacuum leaks can hide, cracked hoses, cracked carb baseplates, etc. Spraying WD 40 at potential leak areas will help find the location if there is a leak. You will hear rpm rise or fall if you spray an area where a vacuum leak exists. Carb cleaner works also if you feel sporting.
Well after changing multiple intake gaskets and timing chains / gear drive, turns out to be that damn perceys ajust-a-jet...mot going to bad mouth the product but i guess i had a bad one. It worked great but the screw was a tad tight "probally cross threaded" and after adjusting it a few times it probally elongated the hole...so now i just have that of idle stumble to kill and i'll be on my way.
