I built a flat top 350. I had some 882 heads that I got from craigslist that were supposed to be fresh from machine shop. They had sat for several years by my garage door and got rusty. I removed the valves and put in an organized tray and marked the heads with a die grinder so the correct valves went in their guides. I took them to a machine shop for vatting and he had to surface them because of pitting. I lapped the valves and reinstalled with new seals and Z28 valve springs. I got the car running and it has a miss. I drove it to work all week and it has gotten worse. I pulled the intake and the side runner gaskets were oil soaked. Oil was in the heads intake runners but dry in the intake manifolds runners. I suspected it was my miss. I swapped intake manifold with one I had on the old motor and fired it up again yesterday. Still has the same miss and low power. I had swapped out distributors and a coil in the HEI thinking it was the problem. No luck. I have assembled many small chevys and freshened up many heads. I've always messed with small blocks and they're all I know. I consider myself pretty good on them but this issue has me lost. I would say that I have probably assembled about 25-30 small chevys and drag raced many. Any ideas?
