Please do tell us what that little 350 has? One of the easyist one I have done is a complete vortec motor with just a freshen or the rings rods mains and the addition of one of GM cams. The cam came from a marine motor and is the same one used in the basic GM 383 build. Last three numbers are 395 and has a light blue paint mark near the end of the shaft. This and a set of 1.6 rockers and you have what GM call the Ram Jet 350. You can use the stock valve springs with this cam and rockers with no problem. I have this one in my weekly bracket truck, 4425lb with a th350 and a 3.42 gear. Mid to uppers 14s at 93mph if the wind isn't blowing to hard. I do have it running with a carb and a HEI to make it simple. GM says it should make 350hp and 400tq and it is one heck of a tow vehicle with all that TQ. I did all the work my self and with out the intake and carb I have a little over $280 in the complete motor. If you really want more then get the GM HOT CAM and upgrade the valve springs.
