On the job deal, have you considered or tried some practice interviews with someone you trust? Maybe something simple you are overlooking. Maybe have someone video you answerin questions or speaking about yourself....trust me, it goes along way.
Thanks for the suggestion, but I'm confident I know how interviews go. I've had quite a lot. Half the time the people interviewing me are surprised at how well I do during the process. Yes, that sounds very cocky, but it's happened.On the job deal, have you considered or tried some practice interviews with someone you trust? Maybe something simple you are overlooking. Maybe have someone video you answerin questions or speaking about yourself....trust me, it goes along way.
if your eye sight is great, or better than most of the "old farts" you know... and you have a predisposition for perfection (as good as you can get with the tools you were given...) and that paint marker line may seem too fat to be precise, make yourself some form of straightedge that you can line up with... say... a broken hacksaw blade, screwdriver for uh... glasses, and scrape some of that fat paint mark line so the "thin" unpainted section becomes "highlighted" and then you can really get precise if you run a thin black line on the timing pointer.just an example... 7.990" (diameter of small block chevy "400" dampener...) multiplied by 3.14(pi) equals circumference of that dampener in inches.
divide that number by 360 degrees to give you the distance across each degree in inches.
multiply that distance by 12 for your initial timing start point... or 10, heck! make it whatever amount of degrees you want...mark that set point.
multiply that same 1 degree of distance by 36 to get a "distance" from your "calculated" ZERO mark (important!) for a sensible "total" timing mark.
paint your marks in colors that mean something to you. that way, you won't need a fancy shmancy dial back timing light.
just make sure your marks are on the right side of zero...a pencil and paper still work when batteries don't.
when you have more time than money, run what ya got! many ways to skin a cat eh?
when you are using these methods... using 3 decimal points is a good standard. .125=1/8, .063=1/16, .625=5/8... i wouldn't hesitate to call .132 "one eigth" because your paint marker needs to be seen to be effective. a good eye will let you place that mark in the right spot so "you" know what it represents when you see it lit up...
Been there done that. If it comes down to it, once summer comes I'll just end up working where my dad works making 17 bucks an hour to start. EFCO is where he works. Construction and manufacturing type deal.This thread is getting wayyy off track lol. So, to close this off I suppose, make sure your timing is right before you do anything to your engine. 😀Ever do any fillow-ups and see why you did not get selected or what you could do to increase you marketability?
Like, what would it take or what should I do to make me more of a viable prospective employee or candidate?
Look bud, I am sort of a big guy, I have a heavy voice, so I have to consciously remind myself to come across extra nice and polite or I am the guy with an angry sounding deep voice.... it helped me get the jobs I wanted. Have to have someone that will be honest with you watch said video.
