I didn't know that, thank you.since small and big block mounts are the same, throw a sbc in it and cruise.
Highly unlikely. I view it as an unnecessary waste of gas, and big expense, which is not something I'm after with this project.The only problem with that is once he starts driving it he is not going to want to pull it out to put his dream engine in.
FTW!Literally anything that runs that you can get your hands on.
That is some priceless info right there, thank you!when you go to the 2jz, get a rear sump oil pan if you dont get one with it already on there. most all gs300 and is300 have front sump so you will need a rear sump from a supra or a sc300. it will allow you to mount the engine lower in the engine bay without hitting the steering linkage. the sc300 or the non turbo supra oil pan will have the location for the turbo oil return but it wont be drilled out.
