Engine pull question
Baker7888
665
115
Maine
Hey all, preparing to pull the original V6 out of my 78 Malibu. It has the th350 which I was planning on keeping but going to have it rebuilt. My plan is to drop the trans from underneath the car, and then pull the motor when my hoist shows up. I know with F body, with the trans x member removed, the motor will tilt back but comes to a rest right before the distributor touches the firewall. My question is, Is G body the same, And am I correct on pulling trans first, then motor? I dont want to pull them together.
565bbchevy
9,614
12,683
Michigan
You can pull the trans first or the engine first and leave the trans in but the trans will need to be supported in the front, I just use a 2 x 4 laid across the frame and 2 tire irons one on each side through the pilot holes
Baker7888
665
115
Maine
Thanks for the reply. Id rather pull the trans first, my engine hoist isnt here yet anyway. When pulling trans first, is it OK to let the engine tilt back or does the engine need support?
ELCAM
1,124
1,270
Put a piece of 2X4 between the block and firewall.
oldsmobile joe
2,067
3,053
mpls
remove the distributor cap so you don't crack it when if the motor does tilt back.
CopperNick
3,357
3,018
Canada
Ah, for myself, the last t-box/engine split i did, I used a small floor jack with a chunk of 8 inch board on it under the oil pan to take some of the load and support the assembly once you have pulled the crossmember and while you go diving for the various bolts. The trick with the large width board is that you want it to be wide enough that the motor weight isn't on the bottom of the pan, it is on the pan walls. That way the pan bottom doesn't get dished in or dented.
To grab that t-mission from below, unless you have a lift, you are going to need sufficient room to get the floor jack in and then get it plus the t-mission out. With a floor jack set up with a t-mission adapter plate, that works out to around 20+ inches. Most normal hard stands will not get you that high without having them sit on some kind of wooden beam. For what I wanted, i borrowed an idea from another thread here on the board and built a group of frames from 2 x4 laid flat that I could stack one on top of another to get my height. This is a static lift but it is stable and holds a load quite well. There are pictures of them in use, located on the Non G-Body forum hereabouts; not sure of the page number, it was back in the early spring of this year.
After that it is all mechanical. The only complication is that, if you want to leave the starter in place, you might have to drop the oil filter to get some room to access the converter to ring gear mounting bolts. The t-mission to engine block case bolts will be a PITA but can be had using extensions and a swivel or two. One thought would be to make a list of everything you have disconnected or unbolted so you can review what has been done to ensure nothing was missed. Other thing is to bag and tag the fasteners. Even if you decide to go ARP or whatever, the old fasteners make good samples for getting the right replacements the first time. If ARP, use their spec for torque. You can go the old "two grunts and a groan" method but a torque wrench, if possible, is easier and offers greater peace of mind.
64nailhead
Goat Herder
Dec 1, 2014
5,710
12,219
Upstate NY
If no lift, then pull the engine 1st and trans second. A TH350 is easily pulled through the engine compartment. But it has to be separated from the motor before pulling the engine and slid back far enough to let the flexplate clear the trans bell housing.
I’ve done it like this close to 10 times in the past 5 years - it’s really not that difficult or much extra work.
Regarding lifts, they are great (absolutely the best), for swapping torque converters. After that, I’d rather do it on the ground.
565bbchevy
9,614
12,683
Michigan
I have pulled many engines and transmissions separately but only if that was the only thing I needed to pull, if I need to pull them both then I do it at the same time and separate them when they are out.
Reactions: 5 users
pontiac guy
582
843
Royse City, TX
Pull them at the same time but be sure to plug the output shaft or you will have a mess.
Reactions: 4 users
