like i said, i doubt it's the problem, but i've seen weird sh*t happen. and it's easy enough to do, i figured what the hell.
DRIVEN said:You weren't very specific about your engine specs so I'll have to make some assumptions. A 421 is a huge SBC so it probably has a huge (long duration) cam. That means low manifold vacuum - especially at lower RPMs. Carburetors are vacuum operated. Pull all your plugs and see if they are fuel fouled. If they are, replace them and see if you can get it started again. Then it's time to make some adjustments.
I had a similar situation while breaking in a small block with a long duration cam and a stock tuned carb. At anything below @1800 it would choke out. The low vacuum was causing 2 things; the power valve would open (go rich) and fuel would pull through the primaries. This would cause the engine to die and be nearly impossible to start. I dropped down to a 5.5 power valve from the 7.5 that was stock in my 3310. You probably have a 6.5. I then adjusted my secondaries open just a crack. That allowed the primaries to be closed which let the idle circuit work properly. At that point I was able to run it enough to do jetting changes as necessary. Good luck.
88olds421 said:Well, finally got the engine builder over. After cranking it a few times couldn't even get the engine to fire a cylinder. Checked the plugs and they were all fouled. He told me I needed to let the cylinders air out since they are now fuel soaked. It needs to be a nice day and we are suppose to get rain for the next few days. So come Friday or Saturday going to let the cylinders air out and put new plugs and go from there.
