I disagree, 400 hp is stress a gbody was never designed to take with their thin gauge, mild steel construction. 110 hp out of my old V6 was enough to crack my roof just normal driving. At 400 I have seen glass blow out from body twisting and lower LCA mounts twisted and cracked rear frame rails.
$150 is still a lot cheaper than $650 plus no credit nonsense. All I know is I have a friend with an 11 Vette and a LS2 swapped 85 Monte, he paid $700 for his HP Tuners Pro and had to pay an extra $100 to be able to use it on the Monte too. Personally I am happy with my Qjet which is just as good as EFI for street driving and I can tune the a/f mixture with a dwell meter. If I was more into drag I might be more concerned about EFI.
What I said is indeed correct sir. Due to the deep skirt factory block, the LS crankshaft is constantly rolling around in the oil supply, and as RPM levels increase, the factory pans can actually become empty, starving the engine of oil. Even the LS7 dry sump setup could not completely fix it, and it is incorrect that it is just packaging as you claim. The oil pumps in past engines like the small-block Chevy was driven from the camshaft, which turns at half engine speed, and the LS-style pumps are driven at full engine speed from the crankshaft. The issue that raises its ugly head in this situation is cavitation. The factory pan designs are very shallow, and the majority of the oil volume is housed up inside the deep-skirt block. GM attacked the oiling issues by creating windows as you stated, inside the factory blocks, allowing the oil a way to move throughout the lower half of the engine, but this also creates extra windage. This extra windage is why LS PCV system suck up so much oil and why SBCs last longer on road courses than LSs.
The LS also has alot of internal oil “leakage”. A stock SBC takes 5 gallons per minute of oil at 6,000 RPM to lubricate everything, a LS uses 18 gallons per minute at 6,000 RPM because of greater leakage. There is very little metal to hold the main bores and cam tunnels in place because of the windows and can lead to wear problems. All cams flex a little and it’s usually no big deal, but in the LS the cam and crank are like noodles in there, and it wipes out bearings and lifters. I am not saying LS engines are bad, but like everything they are far from perfect. There is a reason why the new LT series is a complete redesign over the LS series.
About installing a LS you forgot custom driveshaft, exhaust piping, wiring harness, oil pan, belt drive accessories, etc. Also using a stock normal flow rad with a reverse flow engine isn't a good idea as it promotes air pockets. Should plan on installing a proper reverse flow rad soon. Most places that I see selling used LS motors like junkyards usually sell them piece meal so they add up quickly, but that may just be my area.
States are supposed to plug into your ALDL port and scan to see if the PCM has ever been reflashed. If you delete the gas tank pressure sensor they should detect it and fail the car, no need of a visual check as they can scan for deleted stuff that should be there. In fact they are supposed to check enhanced EVAP pressure readings to detect leaks, no readout at all means tampering.
Boring out the stock sleeves is expensive, plus the block must be machined to accept aftermarket sleeves, a better shape block is cheaper. That is why a used iron block is a safer bet and to be leary of too good prices for used aluminum LS blocks.
