Also, don't forget, these converters lock so they aren't slipping at cruising speeds.
I understand that totally. The issues I see with a higher stall as recommended earlier is the amount of slippage at cruising speeds. This creates more heat obviously and we all know what heat means for trannies. Anyway I would be fine with something higher on a more 'fun' type of car. Just not for me. I've been there at the ragged edge of street ability. Big cam tall gears dumped 3.5 inch exhaust. To each his own though.
I dont know when the factory tuned ecu hurt you, but I look forward to helping you on your road to recovery in believing the LS motors dont make torque below 3000.Yeah, it makes sense when you think about it. The 2.48 first gear and a motor that doesn't pulling stock below 3000 rpm, 3500 rpm makes sense with more cam and is probably very fun.
wait,you mean the tach bouncing off the limiter outta the hole isn't the flash speed?Flash is what your tach blips to when you step on it correct? Please explain your method for dead stall? What are you guys paying for a quality 4L80E converter? I am correct only so much stall can be done with the larger diameter converter, seems a 10" minimum is needed on the 3000 up range.
Yeah, ok. I still don't get it. I need to practice on something.Dead stall - what the converter will slip to with no crankshaft rotation (no movement) and brakes applied. If you had a trans brake, where you hold the trans brake to before you break the transmission lol. The flash stall is, as you mentioned where the converter locks at when full power is applied from the motor. Ideally it will be at the same point all the time if you apply full power from below the flash stall point. The flash stall is tuned via different rotors in the TC - they are numbered and I have no idea of the numbering system.
Keep in mind that anything stock will dead stall very low and usually flash below 3200.
