I was in Cali before. The Cutlass is 1 of the cars they look extra close at when it pulls through. It's nearly impossible to do headers in cali. You have to do either the stock setup exactly, or the setup I went with. I've got flowmaster 40s from a y-pipe. It sounds really nice but it didnt result in a performance gain. I dont know where you're at but I got it at an exhaust shop in Concord off the 242. You should just go with the stock system and downpipe. If you have to go back to the smog station several times, that's you losing hundreds of dollars. If you arrive at the smog station with anything but single exhaust and manifolds they are going to look for excuses to disqualify you. Some smog stations do look for the EGR valve and if it's not there or doesn't work you are disqualified. Many headers systems make it virtually impossible to retain the working EGR so it's not that it cant be done but its adding a lot of unnecessary work for no reason; better to just arrive w stock single. Get plates, then do w/e you want afterward - not before..
