Exhaust
AlexSUPR
Apr 21, 2016
Can someone point me to a website where I can find exhaust pipe for an 83 cutlass supreme. I have 50 series flowmeter mufflers already. Every website I been into are selling the mufflers as part of the package. Also, any exhaust system suggestions would be nice as well. Thanks.
9,621
12,724
So are you looking for a larger than stock true dual exhaust without mufflers? And if so what are the inlet and outlet sizes for what I assume are "Flowmasters".
Kwik_Cutty88
1,173
662
Coastal North Carolina
AlexSUPR
Apr 21, 2016
Its telling me it won't fit on an 83 cutlass. Just 85 and up. But they all have same body. I have a th350 and 350 sbc. Idk if maybe this information will help. I tried looking but I had no help.
Kwik_Cutty88
1,173
662
It'll fit. They (Cutlass') are all the same. Are you running the stock crossmember? You will have to clearance it for dual exhaust. I've had this with the stock crossmember, and the Jeg's crossmember.
9,621
12,724
Many times the chart they use doesn't cover every application but it still fits.
AlexSUPR
Apr 21, 2016
I kinda figured that. And I think I do have the crossmember. Ill check for sure. Thanks this helps a lot.
9,621
12,724
You can always notch your factory crossmember and with 2-1/2" you don't need that much of a notch. I modified my factory one to clear my 4-1/2" exhaust.
