Well tried to take advantage of the warmer weather to drop the engine & transmission on the frame to find out the damn Chinese made Anchor mounts has the bolt sleeves molded in at an angle in the rubber. Loosen the mounts, tried with the medium & large persuaders, adjusted the tilt angles as much as I could, swapped sides & used another set of block side brackets & nothing. The bolts will not go thru the other side (or even get in after swapping sides.) I compaired the steel parts from them & the ones that were opened up for the Energy Suspension inserts (an Anchor set that was made in India), both halfs are the same thickness as one half of the other set. Even the bare metal set feels heavier that the complete Chinese ones. I bought these to replace the ES set cause of the fighting with them. Now after properly reading the ES instruction sheet (who needs instructions? This fool ) I will have to attempt again with them being left loose tomorrow (wife permiting of course.)
