shotgun said:I am still trying to find enough data points to compare hollow vs solid.
Think of it this way, if you add 1/8" in diameter, it's kinda like wrapping another 1/8" bar around your solid bar.
Found stats comparing a 14/16 (3/8) vs a 15/16 solid bar. Only being a 1/16" thicker it is 32% stiffer.
Strength goes up by it's square.
A hollow 1"version of the same bar is stiffer then the 14/16 and less the 15/16.
Based on that I would say yes, the 1 1/8" is worth changing and yes it would be stiffer then the 36mm (1 3/8").
I might pop off my 1" rear and try the 7/8" and see how it is with the 36mm front.
Hmmmm, Shotgun, that's some good info... As big and bulky as the 36mm bar is I might just have to replace it with a differant bar. Thanks for that info.
