oh ya ok, you usually lose the lower speeds when the resistor is gone anyways not the high speed.
@View attachment 76336 View attachment 76337
I found the red wire
After I slice it where do I run to to ?
is that the red wire u was talking about I connect to the hot wire on the valve coverThere is a 10 gauge red wire that feeds this (yellow circled) relay which is the feed for the high speed. There is a connector on the passenger sided near the front of the valve cover that has the red wire. As fleming442 that red wire comes from the fusible link attached to the B connection on the starter. It is hot all the time.
U can still send pics of where that red wire connect toHere I was . . . all prepared to go out and take some pics for this poor lad tonight and as usual you all have practically schooled him in a complete rebuild, with pics, tips, and pointers!
I must say, you have quite the Charlie Foxtrot of red wires in that general area.
You can connect it to the battery or alternator VIA FUSED CONNECTION.
Yeait may be, you should trace that wire and see where is leads to and comes from. Do you have a test light and/or a multimeter?
The red wire on the valve cover is the hot wire for the electric choke, I believe.@
