i repaired a small rust spot i had on the outer part of the door today. when i was taking the glass out to get it ready for welding i looked at the inside of the door and it is rust free. i was curious on your opinions for an i dea i got.
do you think it would be ok if i coat the inside of the doors with fiberglass resin so in the future when water gets in it, it may help keep them from rusting. after i coat them i will drill out the drain holes so obviosly the water can drain, but what do you guys think? thanks for any opinions.
