Not my MCSS, but my new to me used 2006 Sierra. Hopefully the knowledge gained from this will help those with rust issues.
Re: fender lips where the outside panel and inside wheel liner are folded inwards and spotwelded. After a few years this folded and painted joint cracks and allows moisture to collect between the inner and outer metal leading to rust.
On my truck I would like to find an easy way to neutralize the rust and still leave a surface that paint will stick to.
The best way is to inject an oil based product to displace air and moisture. The problem with that is paint will not stick to oil the escapes the joint and the oiling must be repeated.
The question is: how to stop rust in an internal joint that allows repainting afterwards. Below is a pic, looking up at the top of the fender lip
I can easily deal with exposed surface rust but the hidden areas are a mystery.
