get yourself a small sheet of 20 gauge metal and drill some holes thru it to practice on. What kind of welder are you using, what wire are you using, is it a shielded flux core or are you using gas. Have you cleaned the paint from the welding area?
So you want me to "go in a circle" like following the rim of the hole? That makes sense. I'll try it again this weekend.Black Sheep said:Stick the welding wire thru the hole, touching one side. Pull the trigger and move in a circle. Grind the weld down. If you still have a hole, hit it again with the welder.
I guess I taught myself. This is my first major welding project (yeah I was kinda excited to weld stuff):Black Sheep said:Filling small trim holes is the first thing you learn when starting to weld.
See photo abovepontiacgp said:get yourself a small sheet of 20 gauge metal and drill some holes thru it to practice on.
A mig 135 with .024 wire on clean bare metalpontiacgp said:What kind of welder are you using, what wire are you using, is it a shielded flux core or are you using gas. Have you cleaned the paint from the welding area?
motorholmes said:See photo abovepontiacgp said:get yourself a small sheet of 20 gauge metal and drill some holes thru it to practice on.
