Finally rebuilding my 7.5
onebadasscutlass
143
detriot, michigan
So it has takin more time then I wanted it to, but I'm finally getting my 7.5 done. Here some pictures of the rear end
onebadasscutlass
143
detriot, michigan
Here is what I pulled out of the center
onebadasscutlass
143
detriot, michigan
Traded some parts for an actual posi unit
onebadasscutlass
143
detriot, michigan
Yeah I had a friend help get it out of the car but tearing it down wasn't to bad. Cleaning it sucked though! Thank god I have a hot water pressure washer at work.
gdouaire
626
439
Québec City, Québec CANADA
compressing the crush sleeve and adjusting the gears, that's a scary parts to me!
Bonnewagon
Lost in the Labyrinth
10,564
14,298
Queens, NY
Looking good! Do you have a pinion depth setting tool? If not, see what shim was under the pinion gear bearings on both the old and new. I'll bet they are close if not the same, and you can use that as a starting point. Then you can use a new crush sleeve and set the pre-load on the pinion gear and be pretty sure you are good to go unless a tooth contact pattern test indicates otherwise.
