i havent fired many hand guns, but i did recently aquire a gen 1 glock17. its 9mm whitch is just about impossible to find anywhere, so im going to glockparts.com and buying their .22lr coversion kit. at least then i can shoot some paper targets...
kornball426 said:So maybe you guys can help me out... At a gunshow today I bought a flintlock pistol for 50 bucks on a whim... But now I'm thinking maybe I got taken. It looks pretty much just like the one in this picture only with without the engraving on the barrel band.
Anyway I took it apart to check it out... And it appears that the barrel is a casting not a forging (I could be wrong, but it has marking that looks like the leftovers from a die casting on the hidden parts inside the stocks) and the flame hole from the primer pan into the chamber isn't drilled. You can see a like guide hole in the side where you should drill a hole if you were so inclined. But is this normal of black powder kits? Which I'm sure it was a kit built gun, if not a prop gun. Do you usually have to drill the hole, and is it safe for the barrel to be cast? I know that black powder chamber pressures aren't that high but being a casting still scares me. Don't want it to explode in my face.
Do you think this thing is meant to be a non firing replica? It seems very sturdy like it's a real gun and doesn't seem really cheaply made... And I took the lock out and it seems well made and the spring is very strong and the frizzen works like it should.
The guy that sold it to me said he knew nothing about it, he took it on a trade from a guy that owed him some money... And if it didn't sell he was just going to use it as a display piece in his house. I bought it to play with, he said all I had to do was put a new flint in it and it would fire.
Still if I'm only out 50 bucks not that big of a deal... I'm sure I can recoup most if not all of that money if I want to re-sell it.
