I got my monte carlo cowl to core braces put on the cutlass this weekend. I wire wheeled them down and sealed and painted black. The location dimples in the cowl were there when i pulled the rubber off and once drilled out they bolted up. I put some 3m stip caulk around the stud to seal it from water leaking out of the cowl.
On the front mounts i had to add about 1/4" of washers to clear where the cutlass core support brackets had a lip on them. This also helped clear the overflow tank on the passenger side
