Im finally getting around to putting miles on my car with the FiTech setup on it. The other day about 15-20 minutes into a cruise I noticed my fuel pump seemingly getting louder as I drove. It went from being unnoticeable with the engine running to sounding like static coming from the rear speakers. I have the FiTech inline pump mounted in the spare tire well. A little while later the engine would stumble if I floored it suddenly. It was fine if I slowly laid into it. Then a little while after that I couldn't take it above 1800 rpm without the engine stalling out only to kick back on when I let off the throttle.
I finally limped it home, put it in park and everything was fine. Revs to 7500 rpm with no stumble or other issues.
I have already contacted FiTech and they say it sounds like the fuel pump is getting hot. Either from aerated fuel or a restriction. Anyone with EFI have any input? I have a stock tank, half full, with a baffled sump welded in, -6 braided line from the sump to the pre-filter to the pump to the after filter to the engine. A pretty basic setup. I have the fuel pump wired up to a kill switch on the ground wire in the dash. No matter which way the switch is toggled the fuel pump still works, that didn't make sense to me being a 2 wire pump. Any ideas?
