Agreed. The info is still accurate & others MAY NOT know/realize.Obviously any metal that flexes can fatigue and fail but since he was going to run a flex fan regardless of input my suggestion is in my opinion run the one least likely to fail
I still think there's a big difference between stainless steel fatigue and aluminumAgreed. The info is still accurate & others MAY NOT know/realize.
There is.I still think there's a big difference between stainless steel fatigue and aluminum
This is my exact engine belt setup...Sure .... An '84 car/engine with an accessory set-up from a later model. As someone who's mentioned working under many hoods in their posts, you should know you can swap parts from a '95 sbc onto/into a sbc from 1955. There are limitations for compatibility, but parts swap over; especially accessory brackets, pulleys, & water pumps.
