I would not waste time with that car after seeing the scale on the chassis. But that is just me.
Where are you located?
You're a far better welder than I am lol I practiced with the HF welder, and all I've done is blow holes through scrap.
I'll give it another shot. I did just pick up a new 10# spool I can play with.
I'd like to convert it to DCEN at some point to minimize the splatter. They're AC welders to begin with. Here's the guide I have bookmarked: http://www.blinkenbyte.org/welder_conversion/welder_conversion.html
I appreciate the response, thank you.
The sweet spot on a HF welder is very small... its right above too slow to feed and with the amps on the lowest setting. When I found it , it was great. I can't remember but I think i changed the feed wheel and bought the smallest flux core wire it will run.
The hardest part is holding my breath when I weld. Proper fume extraction would improve my welding considerably.
A frame off is likely outside outside of the equipment I have available, and definitely outside of the help I have available. Me, myself, and I. My girlfriend pitches in when she can.
If there was a frame off, I'll have to pay to have it done. I'm guessing that'll run well outside of the current DIY budget. I'm definitely going to keep it in mind, as I've thought about it a bit in the past.
Please read some of the threads and links here about body mounts and bushings before assuming that you can't do this. Here's a link I found where someone details how to do this with some 2 x 4 and 4 x 4 lumber and a jack (I would advise removing the gas tank):
http://gnttype.org/techarea/bodygauges/bushings.html
I recommend this thread which explains how to realign the body and frame afterwards:
https://gbodyforum.com/threads/body-mounts-cage-nut-alternative.64256/
I haven't done it myself yet, but it makes sense to do this if needed.
Thats a nice confidence booster. I appreciate it. I knew I should pull the body, I was under the impression a lift was needed, which is how I've always seen it done. The tank is already coming off due to bad gas, the lines are all getting replaced, and I had planned to pull the entire front clip to get the frame up front cleaned and a coat of POR15.
I was planning to send it in to have the rest of the frame done. If it can be a 1-2 man operation, I'll give it a whirl.
Ill check out the links, and search around for some DIY writeups on pulling the body.
Thanks Monte
