Thanks for the pictures! Are you running c clip eliminators or what is the gold color spacers between the axle flange and the backing plate for? Part of the kit? Looks like you gained 3/4" there in caliper location.
Doesn't putting those washers behind the abutment brackets put the rotor up against the abutment bracket? You only have so much room and you want the rotor in the center of that space. Another thing I'm confused about. Where is the emergency brake apparatus? There's no photo that shows it.
on the washers --- no, because i used a 3/16" aluminum spacer between the rotor and the axle... so now the calipers will need to move out also... now a little more clearance between the frame and calipers.
LInk: 3/16 aluminum wheel spacers
see last photo in post #35 for a photo of the e-brake mount. i have not sourced the emergency brake cables yet, but the location is very close to the original, just moved inward
yes, there are shoes behind the rotor that came with the kit. just need to put the rotor on and figure out the cable.
Any idea if these ebrake plates work on c6 4 piston calipers? I would rlike to add a ebrake to my GN .
