I don't mean to swim upstream against popular opinion but i don't believe that a 4 lb difference in flywheel weight will make a drastic difference in first gear take off. Between gear shifts and when you get off the throttle, maybe but not from takeoff. The 327 was all about hp not torque. In order to achieve the best possible hp curve, the engine has to have high air/fuel velocity. Unless I'm missing something, the Holley Sniper 4bbl EFI is rated at 800 cfm, way, way to high for a 327 unless you built it out of some monster expensive internals. (cam, valves, etc.)
The air/fuel ratio that promotes good cylinder burn, flame propagation and power is around 14.7 parts air to 1 part fuel, or very close. In order to stay in that neighborhood, the 327 at 7,000 rpm has a theoretical air capacity of 621 cfm. That's at 100% volumetric efficiency. For a "street" modified engine the maximum cfm rating drops to 540 cfm (+/-) (*click on image below) (stoichiometric air–fuel mixture is about
14.7:1)
If you have the 4 bbl Sniper, I don't think the 327 can keep the air/fuel velocity high enough when pulling it through the big 800 cfm bores. Remember, the EFI doesn't use vacuum to meter in fuel, so you are probably running real rich, especially at low rpm. I would be willing to bet that if you ran the engine at idle for about five minutes and then pulled the EFI, you would find gas puddled in the bottom of the manifold plenum. The rich mix and low air fuel velocity would make for very, very weak performance, especially to get a 4,000 lb +/- car moving from a dead stop.
Borrow a 650 cfm - bbl from someone with 60-64 jets and i think the 327 would wake up. Just a thought.
