Last winter I converted the Monte Carlo to a manual trans with the Camaro T5. John B pedal, Camaro hydraulics, Zoom clutch, and a light weight (16 lbs) flywheel. I also put the Holley Sniper EFI on my 327 sbc I built for the car. I know little about the EFI but from the research I did on the internet, it is a real easy application and simple tuning. My car takes off in first gear like crap. I have to feather the clutch and give it more throttle so it won't stall or jerk you to death. I have been driving stick shift vehicles my whole life (only way to go in my opinion) and have never drove anything like this. I thought it was the EFI having issues. I am rebuilding the T5 now and doing more research and found out the lightweight flywheel is more than likely my issue. This is a street car and not a drag car. Drivability is a must. I am going to get a new flywheel and there are different weights. Does anyone know how to determine the weight, 26 lbs, 30 lbs, or ? I will need? Thanks for the input. Thinking about the 26 lb McLeod flywheel.
