I know Holley specifies that the mounts can only be used with their crossmember, but has anyone tried using Gforce crossmember with the Holley engine mounts?
Way better than my solution.
Just about any crossmember will work if its for your transmission. The worst that will have to be done is you'll need to slot a couple of bolt holes.I know Holley specifies that the mounts can only be used with their crossmember, but has anyone tried using Gforce crossmember with the Holley engine mounts?
I use the Holly Swap crossmember and it is terrible. Everything bolts together well but the frame rail extension is a plate in tension. Buy the g-force crossmember and modify the support plate if you need to like 64 says.Just about any crossmember will work if its for your transmission. The worst that will have to be done is you'll need to slot a couple of bolt holes.
