I was talking to my dad the other day while working on my car and found out we have a 9" rear from a late 60's mustang just sitting in the shop. (I believe it is from a 67 but can't remember) I know its a popular swap into g-bodies but what do i need to do to get it to work correctly?
well for starters you have to make sure the width of the axle is close.... you have to weld all your existing brackets to the 9 incher....plus get the upper control arm mounting kit with bushings and weld that as well...which requires you to measure the pinion angle... you also have to have the driveshaft modified to accept the 9 inch yoke. which requires cutting welding and rebalancing.
it could be a weekend project.. personally id sell the 9 in rear its not needed unless your making a sh*t ton of power.... ive seen 7.5 rears go deep into the 11s !
:shock:
500hp engine sure...but even the beefy 9inch would need some work to handle that power for a long time! If you have the resources then go ahead and do the swap! You already have the parts so make them work Good luck man.
if i were you i would make it a floater right away, you have to remember that a ford 9 takes some 30 hp to turn over, with a floater rear end it will make that much easer to turn over. i know they are a bit more pricey, but you already have the rear end and 3rd member, so why not!
