YaoGuaiCutlass said:pontiacgp said:the El Camino frame is basically the same and you can use it with a few minor mods. You'll see the difference in this picture, the El Camino is on the left and the one you need is the middle picture. The rails on the right is for a station wagon. You'll just have to remove the right side body bushing perch and drill three holes in the frame for the body mounts on your car.
So basically in a sense I can take an El Camino frame and take the arms off the Cutlass (if they are good) and replace the ones on the Elco frame and basically put the body on there with a few minor mods?
if you look at the picture I attached you'll see the perch that has to be removed and the 3 holes you have to open up. You can get the locations of the holes from your old frame
