I would have been easier to find a rust free body from outside the Midwest but I've had the thing since I was 15 and shared some great memories. Had to save it.
Since I'm also in the middle of a Frame Off I looked up how to put it back together. I think it was on here in fact.
There are alignment holes in the front LH side (by emerg brake area) and rear RH side (by rear mount). Use two 5/8 round bars to line up body and frame. That should get you close enough to measure it out perfect.
Hutch
When I worked at the dealer in the body shop in the late 80s we had different color body alignment pins that would correspond to different holes located all over the body .. if you look around the cars there are holes on each panel to align body parts using pins .. they used same type technique on the production line .. but with no measurements that's why the body's where all over the place .. lolI wish I knew that before I measured countless times to get it straight.....
