Frame off question?
Thanks! That's awesome advice. What did you use to cut the 1/8 sheet?
You're welcome, happy to help.
I used my trusty metal cutting band saw. Second most used tool in my shop after the compressor.
It's configurable from vertical as pictured to a conventional drop type as well as it'll do some angles in the drop configuration too.
It's one of those tools that you'd have no idea how much you use it until you have it. I honestly don't know what I ever did without it.
I know that most people don't necessarily have access to such a thing, but there are ways around it. Up until a couple years ago, a friend of mine was still using a vice and cutoff wheels in a die grinder to cut all his stuff. Until I got him to see the light so to speak.
Lol
Reactions: Texas82GP
Lol
Well I guess its gonna be the die grinder. I got a great deal a few months ago for a makita die grinder a drill press with a ton of vices and bench grinder for 60 bucks. I'll have to do what I can with what I've got lol.
Yep, you can only do what you can with what you got. I'm very fortunate to have the great selection of tools I've got now, but it took time and money. I did without and making due with what I had at the time for many years before that.
Just remember, where there's a will, there's a way!
That's looking really good!
To be honest, I don't keep track of the number of hours I put into various aspects of the car, but yes, it can be very time consuming. If I recall correctly, I think I had nearly a year of evenings after work into the frame in total. That includes boxing, reinforcing, rewelding factory welds etc tho.
Looking at your pic, the biggest difference I see between what you're doing and what I did was I rewelded the factory welds and then cleaned up the edge of my weld still leaving a seam, where as you're trying to blend the seam into the lower surface.
It can certainly be done, but that's much harder and time consuming to do.
The only portion of the frame that I deviated from this was on the front frame horns from roughly the crossmember forward.
Because these areas can be seen when the hood is open, I didn't want any seams visible. I made cardboard templates of the lower surfaces from the seams to the edges, then transferred them to and cut them out of 1/8" plate. The plates were overlaid over the lower surfaces and welded in place, then the welds were dressed down and blended in. This made for a much quicker and cleaner finished product IMO.
Just make sure you prep the overlapping surfaces with zinc weld-thru primer or something similar to prevent corrosion from forming between the two sides before you burn them in.
I'm not sure what you're using for grinding and blending, but my "go to" tools for this were 5" 40 grit Walter flap discs on my Dewalt electric grinder, and smaller 3" 40 grit Roloc discs on my 45 degree air grinder for the finer, more detail oriented stuff.
As far as dealing with the inevitable pitting, try and get the surface you're going to weld as clean as you possibly can before hand. You want nice clean shiny metal to weld on. Dirt, rust etc is just contamination you're including into the weld. Starting with as clean metal as you can before hand will not only result in a cleaner stronger weld, but you'll get less popping, less pitting and voids, and better penetration.
(While not necessary, if it's at all possible, having the frame sandblasted first is a HUGE time saver). I had to wait till spring, but a buddy and I loaded it into the back of his truck and hauled it down to the local do-it-yourself sandblasting yard where I blasted it in about an hour for around $100.
Sorry for the long reply, but as you can see there's quite a bit to it at times!
Hope this helps you out.
Donovan
I hope you realize that the way your frame turned out you can no longer call that a G body frame, it looks way too good....😛
Yup agree 100% I actually been working on making a sheet metal brake for bending the peices to box the frame. Gave it a trial run today and it does ok..I just need better and stronger hinges. Pretty easy to bend this peice.
To me the biggest danger is not broken bolts but rotted out bushing holes on the frame. Mostly likely your number 2, passenger side frame mount will be toast due to HVAC drain design flaw. If you can weld it is not hard to install frame saver washers.
how can you call something a design flaw when it lasted significantly longer than it was designed to last?
