Coil over ratings and coil spring rating are not comparing apples to apples (not when using the bolt in conversion style). A 700 lb coil over would jack the car up about 3". Keep this in mind.
DRAG RACERS TYPICALLY DO WELL IN THE 250# (with proper geometry)
G MACHINES TYPICALLY DO WELL IN THE 450# RANGE (with proper geometry)
BIG RIM GUYS TYPICALLY USE A 550# (with proper geometry)
COIL OVER SPRING RATE FRONT END WEIGHT
200 600-800
250 800-1000
300 1100-1200
400 1500-1800
450 1800-2000
500 2000-2300
550 2300-2500
200 600-800
250 800-1000
300 1100-1200
400 1500-1800
450 1800-2000
500 2000-2300
550 2300-2500
