Front Lower Control Arms?
Speedway/UB front upper arms are popular, but they are pieces of sh*t (I know someone is going to tell me they've had them for years and haven't had a problem, congrats) . There is no bushing, its a steel sleeve over the cross shaft that you need to grease, and last I knew there was no seal.
They dont have any caster built into them so when you put 4 shims in the back, and 1 or 2 up front and tighten the bolts down you turn the cross shaft into an "S", and since there are no bushings it locks up solid. Like I said they have no caster built into them, and they arent adjustable so what did you gain other than 1/2 of header clearance? Ive seen them come apart under street use as well, totaled the car.
The adjustable uppers I make address all those issues.
Allstar doesnt actually make anything other than their -3 / -4 brake lines. So usually if its something that is fairly common, like a metric lower, you can get them elsewhere as well. IMCA still requires stamped lowers on their modifieds where as UMP does not, even though most metric clips are on nova lowers, but every hobby stock and stock car must run frame matching arms.
The reason I bring that up is a few years back IMCA techs pretty thoroughly and some stamped lowers bought right out of a catalog werent fitting into the tech mans jig, not sure if they were metric nova or chevelle lowers though, so yes there are stock "ish" lowers available.
LOWERS!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
The question was more directed at pontiacgp in regards to roundy-round use. I'm thinking that whatever those guys are using should be cheaper due to more frequent replacement from crashes but heavy enough to withstand a racing environment. I know there are the UB Machine and Speedway arms at the cheaper end of the spectrum, but reviews are mixed.
the tubular upper are lighter and stronger and easier to work with than the OEM. Plus the tubulars come in different lengths so on the right side with a longer upper you can get the positive camber you need and on the right side you can get the negative camber you need. The UB machine uppers are stronger but not really meant to be used on a street car. The teflon bushings used need to be greased frequently or the cross shaft with rust and destroy the bushing. On a circle track car we used the car a few hours a week and everything is greased before each weekend. I use the UB machine uppers and I grease them every 2 weeks and they last.
this is our Camaro after it slammed the inside wall with some help, we had to cut out and weld in a new front clip but the UB machine upper was used on the new set up. After many late nights during the week we had the Camaro back on the track the next weekend with the same set up specs and it ran up front the whole race.
Reactions: fleming442
Moog makes lowers for an S10 and they bolt up. just have to enlarge the bolt holes at the frame 1 size up. i put them on my Cutlass when i rebuilt the front end and have had no issues.
Reactions: TURNA
