what about getting a spare bulb socket, put that into the housing and then put the housing into a bucket of water to look for bubbles
I do not have spare sockets. I probably will need to replace the original sockets as their contacts are pretty corroded.
You think tape would work to plug the socket holes to test for leaks?
Is it possible the housing is being distorted after installation which exposes a leak.
Maybe the socket is leaking through the channels the wires pass through. If the gasket is intact and you can feel it compress as you tighten the socket that may not be the cause of the leak.
good point, he should install the housing in the car and do the same test in the pool.....😎
