Yes it's 4 wheel discs . So my brake lines will hook up, correct? No other changes?
I would also like to add that if you got QP's base disc kit, it is indeed the Seville/Eldo calipers. They are a mf'er to bleed. To aid this: cycle the e-brake a few times in between bleed sessions. The pistons ratchet out as you use the e-brake, thus reducing piston travel to the rotor.
