G body LS swap cold air intake
Pontiac455
473
76
Just as the title says what r u guys using for a cold air intake? My intake is TB SS with 92mm throttle body....
Streetbu
Know it all, that doesn't
3,797
11,877
Central NY
Made my own with a K&N filter, some aluminum tubing, and a silicone elbow.
doood
Amateur Mechanic
Sep 24, 2020
627
876
I bought some 4-in black matte cold air intake tubing and made my own with a K&N cone filter. Could have been cheaper, but problem free so far.
doood
Amateur Mechanic
Sep 24, 2020
627
876
Not running one. No reason to. I'm using Holley Terminator
Interesting. So I had to do a few googles and seems like your fueling system is based on "speed-density" instead of "mass airflow". Your MAP and IAT are used to determine place on the fueling map. I learned something today. I recall needing to put the MAF in a "well developed" flow field (e.g. away from elbows), and I was puzzled when I didn't see a MAF in your setup. Bravo for your ability to TIG aluminum tubing.
Rgpmalibu
136
152
Made my own with a K&N filter, some aluminum tubing, and a silicone elbow. View attachment 240437
Where's your air filter on this rig? Is it below the plastic fender well? I'm having a hard time keeping my intake air cool so I was thinking of making some kind of air scoop to get some cooler air to the filter that sits above the inner fender well like dood's is shown above.
Streetbu
3,797
11,877
Central NY
Yes, I drilled thru the inner fender and the filter is in front of the left front tire and behind the bumper.
Rgpmalibu
136
152
That's an awesome idea! Never thought of that but I'm going to give it a try. I know I have some extra tubing and silicone connectors. True cold air intake. Thanks!!!
