Re: no reason to compare diffrences.
245 on a 20 or a 17? and was the profile right? again within 26.5" overall is IDEAL, so you really are getting closer to that. I would honestly have to do some math ... I am doing this on paper and frankly ... it's been awhile. weights there are too many variables ... have them weighed ... typical factory sized tires on a steel 14" should be like 35 lbs (guestimate) ... an alloy 20" probably 60 lbs and up (again guestimate)
78monte said:DrRansom442 said:78monte said:Since you know so much, what is the overall diameter of the tires I'm running? and what do you recomend the overall diameter should be?
or did you forget?
smidge over 27" overall ... above the recomended +/- 3% of factory height of 25.5". Your Speedometer (unless recalibrated) is now 6 % too slow and it's their widest point on your rims your tires are about 10" ... which means if you are lowerred or at stock ride height ... you got the lucky with wider, than every other G-body on the road, front wheel wells ... 9.5" at the widest point tires rub like hell in turns. Rears should have ZERO clearance issues with the right backspace rim. BTW before someone chimes in about their Regal or 4 door, they are a tad more forgiving.
p.s. a 78 isn't a G-body and yeah my siggy is off ... neither's the 81 but it looks just like the 82-86
Ok.. Went and took a look seems I made a mistake... I'm running 245's all around.. My old 17's have 255's on them..
So it looks like my overall tire diameter is 26.8" do you really think that is terribly tall?
And like I said no rubbing issues at all in the front period.. regardless of what you say.. I'm telling you my car does not rub and it's lowered.
You keep saying "donk" and my car is not even close to a donk, to be honest I can't stand them and would never own one (But I would never bad mouth somebody's ride because that's what they like either).
I wasn't aware my 78 monte is not a g-body could you tell me what it is?
Oh and how much do my rims/tires weigh too? lol..
