Gas gauge stuck on half tank.
druggles85
Pendejo
Oct 25, 2009
282
468
Exeter, NH
gauge was showing half a tank. It made sense at the time because it actually had about half a tank...
Now I have a new tank and it's empty and the gauge is still showing half a tank.
I unplugged the pink wire and grounded it to the frame. That didn't change anything.
What would be my next step? Poke the needle with my finger and swear at it? I'm assuming if the circuit was open somewhere it should swing up to around a tank and a half.
pontiacgp
blank
Mar 31, 2006
29,270
20,391
Kitchener, Ontario
if you unplugged the pink and nothing changed I would check the ground. I hope you put the ground wire on the tank before you installed it.
druggles85
Pendejo
Oct 25, 2009
282
468
Exeter, NH
But shouldn't grounding the pink wire to the frame make the gauge swing to empty? I keep wondering if it just corroded from sitting 20 years and is stuck lol.
melloelky
4,162
9,569
mass
if the sender's out,it's easy to bench test it with a multimeter.
druggles85
Pendejo
Oct 25, 2009
282
468
Exeter, NH
And I knew that. And I have a few multimeters. But for whatever stupid reason I just slammed it together after work one day without testing anything. WTF me.
So that may or may not work. But that's a future problem. The gauge position should change open circuit vs grounded, I don't feel like half a tank is ever a point where it should fail.
Actually where do the gauges rest when the ignition is off? Maybe something's not getting power from the ignition. I didn't notice any chewed wires when the dash was out but this car had a pretty serious mouse problem.
melloelky
4,162
9,569
mass
it should rest on E when you shut it off.
did you pull the sender ground off and see if the gauge pegs past full?
druggles85
Pendejo
Oct 25, 2009
282
468
Exeter, NH
Yeah no movement at all. I really want to yank the bezel and just push the needle back and forth with my finger. You should have seen all the mouse piss rust on some of the stuff in this car. LOL
melloelky
4,162
9,569
mass
i had a similar problem this summer and it was the gauge.it did what it wanted.
druggles85
Pendejo
Oct 25, 2009
282
468
Exeter, NH
My Chevette used to do the tank and a half thing all the time. Did it so much I actually cleaned up and moved the ground... I plan on driving this car more and would prefer to not keep track of milage... Especially since the trip odometer won't reset.
druggles85
Pendejo
Oct 25, 2009
282
468
Exeter, NH
I have a quarter tank of gas!!!
I bought a gauge cluster on eBay and robbed the gas gauge out of it. Plugged it in and it went to a tank and a half. Grounded it out and I went to empty, plugged in the sender and it pointed to a quarter tank. I'm assuming that's pretty close to right.
